I bought a VW T4 a couple of months ago and it never started without (nasty) easy start. I've read a few things online and tried different solutions none of them worked at the moment.
Here what I tried or change :
- Battery
- Glow plugs
- Glow plugs relay
- Timing belt (change and adjustment)
- Temperature sensor
No improvement whatsoever.
Any suggestions of what I should do or check ?
- Battery
- Glow plugs
- Glow plugs relay
whats the mileage on the engine ?
sounds like the internal seals on the injection pump are worn and the pump cannot build up enough pressure (133bar) to open the injectors .
i had my pump rebuilt and it worked great after that T:
pumps are usually due a rebuilt over 100k miles ;)
