HI there
I wanted to check the operation of the pcv valve but i see its under a plactic cover ontop of the rocker head cover. I cant seem to find a wayt to remove this plastic cover off as it seems to hit the inlet manifold. Is it really necessary to remove the inlet manifold just to take this plastic cover off?
I was considering to destroy the plastic cover so i can get to the pcv valve but im not sure if the valve is somehow held in place by it.
Then just run without the plastic cover.
Pete
