Please can anyone advise as to where all the fixing bolts are between the turbo and engine block? I have removed the 3 17mm. nuts on studs that I can find, and have removed all from the exhaust manifold but I still cannot get the turbo off. I need to remove the turbo to replace the cracked exhaust manifold which is now loose and ready to remove once the turbo is off. Any help will be very welcome. Thank you.
Brilliant ! So many thanks for your very helpful advice and superbly clear photos. I am sure this is the one fixing I have failed to see (I have searched the horribly soiled engine for days and fumbled with my fingers like a blind man and clearly had missed this bolt. I will be back at the van in the morning now feeling a lot more confident with your help. Many, many thanks again for your great advice. I will let you know if I succeed. Chris
