Brand new double seat swivel base designed by the Customshop team (Community Registered Design 001382212-0001). We have been manufacturing and supplying VW camper components to the trade and public for over 10 years now. The VW T5 camper van double seat swivel base is the most compact seat base on the market with all 4 locking points hidden away, it has a more streamlined and barely visible look from the outside (raises the seat by 38mm). The locking points work on a unique 1/4 turn 'quick release' system so removing all 4 fixing bolts and rotating the base takes literally seconds! They are manufactured in the UK and made from 4mm laser cut steel, and have passed M1 seat belt anchorage safety tests using a pull test on a specialist test rig to EC Directive 76/115/EEC as amended by 2005/41/EEC which is a standard requirement for most insurance companies when making this type of modification to your camper, and also peace of mind when transporting your friends and family around. The base allows you to rotate the double passenger seat 180 degrees and lock the seat in the reverse position to completely transform the living space of your camper as well as still maintaining your under seat storage area. It also is compatible with caravelle rails, drivers swivels / arm rests and has no rattles.! Fits all T5 models (inc facelift) and fixes directly to the existing floor mounts so no additional drilling required, installation takes approximately 45mins from start to completion. Comes with step by step fitting instructions. Any questions just drop us a mail and we'll be happy to answer them for you.
http://www.ebay.co.uk/itm/291138330435?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Also coming soon a range of affordable flat pack storage units for your T4 / T5 conversions.
http://www.facebook.com/customshopdesigns
