Hi, can anyone recommend any good LED upgrade headlights please and were they an easy fit? I have tried the brighter lamps but they don't last long. Hope you can help, I have a 2009 T5,
Gary
Special Rapporteur
Unfortunately not, because aftermarket LED lamps are not legal for UK road use.
Probably the best bet would be the midrange brighter halogens. The very high brightness ones have a much shorter life, but I've had a pair of Osram Nightbreakers in mine for almost 6 years without a single failure, so they seem reliable enough. Though not quite up to the brightest, they are still a worthwhile improvement over standard halogens.
Thanks for your reply I will try the ones you recommend, would you know if the lamp type is H4? I can't find my previous packaging, thanks
