1 - 13 of 13 Posts
I keep finding water under the rubber floor on the offside of the cabin i have sealed one hole I found but it is still leaking from somewhere and i cannot font it, any suggestions?
evrywhere :ROFLMAO:
look around the windscreen, the bulkhead (underbonnet), heater air-intake (underbonnet), door seals. roof (YES, t4's rust ;)), the seam where the roof & windscreen-pillars meet (the sealer cracks & water gets in & runs down the pillar then gets to the door-hinge area thats foal-filled so overflows into the cab)
Rich.
  • Like
Reactions: joethewalsh
Full of Cr*p....
"Also removed any rust and then replaced" ......
Maybe you should NOT have replaced the rust? :whistle:
Sealing the windscreen properly often involves welding new pieces of metal in.
What year/style is it?
evrywhere :ROFLMAO:
Rich.
Thanks Rich I will check these out, i have just resealed the roof but the water could have been there prior to me doing that, when the weather improves i will take out the seats and lift the rubber to get it dry again i really thought i had cured this problem :(
Tom
Hi, thanks for the reply, the van is a t4 high top 1996. the windscreen surround was in good condition and only had a couple of small rust spots so I'm pretty sure its not coming from there.
Tom
Discussion Starter #8
i have just ordered some "stop that leak" spray to try under the off side wing where i think the water is coming in, has anyone tried this before? I will keep you posted so watch this space.
Tom
I had this on a '97 ABL, after looking everywhere it turned out to be a cracked heater matrix.
Taste the water** , if it's sweet it's coming from the engine.
HH
** Ethyl Glycol (anti freeze) is poisonous, so don't take a gobfull - tip of the tongue will do.
Discussion Starter #10
Thanks HH maybe i should run the engine for a while and see if any water comes in, have the seats and flooring out at the moment to try and locate it so thanks for the info.
Tom
Discussion Starter #13
I've now removed all the old sealant from the roof where the high top meets the metal roof and resealed it with good quality sealant, let it cure for a few days then hosed the whole van for at least 30 minutes and it is completely dry :) I'm going to leave it for a few more days just to make sure before putting it all back together.
thanks to you all for your help and suggestions.
Tom
1 - 13 of 13 Posts
