In a bit of a panic, my T5 has had a leak, which seems to be the water pump, head gasket,. no water in tank, tried re-filling and coming straight out of bottom of engine. Any ideas what this could be? :confused:
DON'T PANIC.... or so said Douglas Adams.
If it's running straight out of the bottom, it could be a burst hose, a damaged radiator or a hole in the block.... then you can panic.
No really, I hope it's something simple.
Don't whatever you do run the engine without sufficient coolant, otherwise there will be a bit hole in the wallet.
