Hi all,
T5 130 flashing water warning red light light on dashboard.
Resets if ign switched on/off
I know this is overheat ,or low coolant warning but read that it is also water in fuel.?
Coolant level is ok,sensor wires are clean,temp gauge seems to rise and fall ok.
If so,
as there is no drain point on the T5 fuel filter what is recommended way to drain it?
If so,
