Hi, I am replacing the water pump and timing belt on my 1998 T4 2.5 petrol. I believe it has an AET engine code.
I'm confused about the guidance relating to the need to replace the cam pulley should there be a certain number of teeth on the existing water pump pulley. I understand that the replacement cam pulley is part no. 023109111D but how do I know whether I can do a like for like swap with the existing pump or need a different cam pulley?
Many thanks
