Hi guys
Was wondering when I change the water pump it came with a O ring seal is this the gasket?
If not does it need a gasket and does anyone know where I can get one - part number would be great
I have a T5 on a 2008 plate 1.9 BRR engine code
Many thanks
The o ring is enough to seal, if you really wanted you could try a gasket sealer lightly spread on the mating surface prior to fitting.
As regarding changing it is common practice to change the pump at regular intervals corresponding with the timing belt .
馃憤馃憤馃憤馃憤
Thanks Fraseb01 (y)(y)
Would you put gasket sealer on or just rely on the o ring gasket - I didn't want to introduce a problem. - sorry not done this before
