hi all,i need help:D
i have a weird fault when i put main beam on my n/s headlight stays on low beam and my n/s indicator stay on but dim and my rear lights are normal but rear n/s indicator stays on but again its dim and then when i put my n/s indicator on it stays as it was premently on and dim???? but when i put my headlight switch on low beam my lights are ok and indicators work as they should??? hope that makes sense?
Hi David
Have you put in any new bulbs recent, if not it sound like a bad earth. I have seen this when new bulbs have been fitted incorrectley
Frank
Sounds like you got dodgy earth mate. Check the headlight plug (which plugs into the back of the light bulb) the plastic has a tendency to melt!!! Maybe just check all the wiring (loose / melted) it's the only things I can think off?!?! :*
Good luck mate and I hope you find the cause T:
Super Moderator
Sound like an earth fault on your high beam. Like above says, try swapping bulbs from each headlight. Check Multiplug or wiring in headlight. :*
sound like a bad earth. CLEAN THEM UP BUDDY
