I dont seem to have any power at the following fuses
4,9,10,16,17,20 and 24
trying to find out what these fuses are used for anyone have an idea please
Ignition was on
Just purchased the van abd ran vcds came up with some fuses being intermittent, was told to check fuses but those that show no voltage do not show in 5he scan except the rear wiper which doesnt seem to work
It gets tricky with fuses in VW vans, mpv's, it's been mentioned before, year model, month of manufacture, Transporter, Multivan, Shuttle, etc, and then equipment levels, all have a bearing on the fuse layout & number of fuses.
Special Rapporteur
Generally fuses don't go intermittent. If they do it's typically if they have been overloaded, but you can usually ~see~ that.
As said above, nobody is going to be able to tell you fuse allocations without knowing what van you have, as they changed very frequently by year and model. It would also help to say which of the fuse panels you are referring to.
