i have an exaa 2.5 102 t4 and had it serviced when i first got it..
the service reminder has come up on the dash so i need to put it in again,
but i dont actually know what they do, i know they change the filters and oil....
but what else.. as £200 ish is quite expensive for just that.. isn't it!!!???:ILU:
oh yeah the service due now is around the 80,000 mile mark:ILU:
Has the cam belt service been done ?? thats the expensive one
Basic service would be:
Oil
Oil filter
Air filter
Fuel filter
Cabin/pollen filter
Sump nut washer
Diagnostic VAGCOM check
Screen wash top up
Extras might be:
Coolant flush & replace
Brake fluid change/bleed
Plus of course visual inspection for anything worn out.
BMW? You gotta be serious!
if its done by a vw dealer there is no such thing as a "full" service, everything has its time/mileage dependancy, inspectons are carried out 20k,40,60k,80k oil changes every 10k, 30k, 50k etc etc
all services include oil and filter change
fuel and pollen every 20k miles air filter every 40k miles
help or confusion lol
ok, still baffled lol
so what would i be looking at having done at 80,000 service, so that i can make sure it gets done!:ILU:
80,000 mile service
its an inspection so filter wise
oil, fuel, air and pollen, the service should take no longe than a couple of three hours lol
vw time 2.20tu, its a full inspection and if you havent had it done get the cambelt etc done at the same time
just looking over and inspection sheet for an 02 plate 102
electrics
front and tail lights, check function
warning lamps and horn, check function
vehicle system check, perform test (guided fault)
service interval display (reset)
vehicle exterior
door arrester and securing pins, grease
wiper blades, check for damage and park position
tyres
depths and condition all round (report)
vehicle from below
engine oil, drain or extract, renew oil filter
engine and components in engine compartment (from below) visual check for leaks and damage.
gearbox, final drive and drive shaft bellows, visual check for leaks and damage,
brake system, perform visual check for leaks and damage
front and rear brake pads/linings, check thickness
underbody protection, perform visual checks for damage
exhaust system, visual checks for leaks, security and damage
track rod ends, check play security and bolts
swivel joints, visual check of swivel joint boots for leaks and damage
steering, check bellows for leaks and damage
engine compartment.
engine components in engine compartment (from above) perform visual checks for visual check for leaks and damage
windscreen wash/wipe system, replenish fluid
cooling system, check frost protection and coolant level
dust and pollen filter renew filter element
power assisted steering, check oil level
final checks
headlight alignement, check
next service sticker
perform roadtest.
help?
cheers dazboi01, really helpful,
i wish i was near you guys as there isnt many "trustworthy" mechanics around my area!!:ILU:
on that note, another post needed!!
if im honest thats whats on a vw service list, there are some garages and mechanics that will do alot more than that for your money, but being a main dealer we service and repair according to vws recommendations
