Hi i have a 1.9 td the clutch is held on with some sort of multi spline bolt.
Does anybody know the proper name for the tool and also the size i need to order.
i knocked an af socket on to undo them but i prob wont get away with this to re tighten them ive ordered new bolts but need to know socket to order to fit them.
the bolts are about a 7mm bolt they are bigga than a 6mm bolt but smaller than an 8mm bolt i have not got a 7mm nut to try on it but the bolt head has 12 splines similar to the cv bolts but external splines instead of internal.??
if i look up xzn just the type for the cv comes up any help please :(
MM i could not get a 9mm to go on so in the end i tapped a AF socket on which did undo them i will have another look on the bench tomorrow instead of while standing on my head under the van like today lol
Thanks T:
Ha Ha a 9mm socket that doesnt belong on that socket rail it only had the hexagon fit .
i found the matchin socket to my set and that fits fine like you say a ring spanner would also of fit.
Thanks for your help Bud sometimes its difficult to see the wood for the trees
Chees Bud T:
