Hi all.
Probably stupid question but...........
ive got T4 2.5tdi camper interior running on audi rims with 235/40/R18 load rated tyres. What psi should they be
Mark
hi Mark
obviously completely different rims and tire setup from standard... the standard psi plate is on the "b" pillar drivers side just under the door catch....
if your new tires are correctly load rated you need to look on the side wall of the tire and it will say some thing like :
max load 860kg at 70 psi, the max load is what your tire is rated at, if your tire is over rated ie, 102 and you require 97 rating then you can lower the psi abit
all tires are different, ive had tires saying 55psi and my new ones say 70 psi
hope this helps but there is no definitive answer
