anyone know what vacuum pressure a healthy system should pull?
preferably for an ajt engine?
been searching but cant find anything.
thanks, rick.
we seem to be suffering same problem,with same engine.
vans going into mates garage tommorow for waterpump n crankseal,ill see what he thinks of vac pump pressure.
currently if i place my finger over pump,no suction on idle really?give it a rev and it will suck finger to pump,and then keep that amount of pressure until i pull hand away,then its the same until revved.this brake problem started overnight?not a gradual fault.
checked vac pipes,no leaks splits?did have the hissing brake pedal earlier in year,but removed servo,sprayed some lube into it and gave a few presses past whewre the pedal would normally travel,been fine since?
ill post up any info tommorowT:
added=just spoke to mech,says pump should pull better suction than it does currently on idle...........bloody van!
yeah was gonna say mine pulls to my finger on idle so yours sounds like a bad leak or possibly the vacuum pump has gone.
had both problems on mine, just want to find out how hard the new vac pump should be sucking.
ive put my finger directly onto pump,still as poor suction.
ill post up tommorow night after ive been to garageT:
Have any of you noticed any rattles from the engine , at all ?? Mine rattled liike a good,un , for a while , eventually I realised it was vac pump valves , but braking was still acceptable .Got a new vac pump, brakes still not what I had hoped for , so removed pads , found them glazed because of lower pressure , removed the glaze ....what a difference ..!! My boat is on a un-braked trailer , and I cant have braking issues ..!! I just wonder if a vac pump valve has gone for someone ??
the amount of rattles my ajt has,its hard to narrow them down!:*
but no,vac pump hads been quiet,then thought it would join in with rest of the mechanicals!:(
