I have just done my lower ball joint after a knocking I have had for months, this has stopped that but...
I now have terrible wheel shake at anything over 40mph!
May be worth mentioning my drive shaft popped out while doing ball joint, so lost a bit of box oil, but got it straight back in.
wheel is tight & centre spacer is still in place, could it just need ballancing & is it possible that I did not notice this before as there was so much play in the ball joint it was "ironing out" this wobble.
Any help pls :confused:
Have you checked everything is done up correctly, espescially wheel studs?
Highly unlikely you will have thrown the wheel itself out of balance just by taking off, you haven't knocked a balance weight off have you?
Have you checked tyre pressure?
Everything is tight dont think I have knocked a weight off! Wheels are 18" lenso's so will be bloody anoyed if they r buckled at all.
Will check I have the ball joint on correct way round in morn as these are slightly offset I believe.
Am really peed off though as I thought I was finally going to get rid of all the knocks & rattles!
Try swopping wheels - maybe fit the spare to the one youv'e changed the ball joint on and see if it improves.
//NiSk
Off the wall thought - the countersunk screw holding the disk on hasn't come loose, meaning the wheel's held off from seating properly when its tightened up?
