There are answers to this question I don't really want to hear.What it is ...I have found a relay(buzzer) number 4 in one of the pockets in my 1994 2.5 petrol Eurovan and was wondering if anyone knows where it should go.By the connection spades on it,it could fit above the fuses in either position 9 or 10.I presume it warns of door not closed or something and the last owner found it irritating
I'm guessing 9
Relay locations on fuse/relay panel
1 Fresh air blower relay (105)
A/C relay (140)
Relay for climatronic (140)
2 Rear window wiper/washer relay (72 or 174)
3 Not used
4 Load reduction relay (18)
5 Not used
6 Emergency flasher relay (21)
7 Headlight washer system relay (95)
8 Programmable washer/wiper intermittent relay (99)
9 Warning buzzer for parking light (36)
10 Fog light relay (53)
11 Busbar for horn
dual horn relay (53)
12 Fuel pump (FP) relay (167)
Glow plug relay (102)or (103)
Relay locations above fuse/relay panel:
Seat belt warning system relay (49)
Idle boost relay (125)
Relay for A/C shutoff (147)
Idle air control (IAC) control module (155)
Load reduction relay II
Coolant circulation pump relay (53)
Secondary air injection (AIR) pump relay (53)
Thank you very much for the info.....including all the extra.
I will go now and put it where it belongs.
Cheers David
T:
