1 - 10 of 10 Posts
Hi.
I have a 97 2.4d and was wondering where this glow plug fuse is? I have been reading about it a lot lately and just want to check it
I think it's number 15 from the left of the fuse box mate. Fuse box is located on the drivers side of the dash. Hope this helps.
We all know what thought did.
The glow plug fuse is in a black plastic box in the engine compartment. Often found on the inner wing. Follow some of the wires from it as there is also a box with the rad fan fuses in the engine bay.
Can't give exact location as mine is a LHD and earlier.
Mine , (94 2.4 ) is on inner wing , driver side , to left of the servo unit , as yr under the bonnet . Heavy wires going to it . Only £2.50 (ish) a pack . Run a jump lead from batt. +pos. to glo-plugs to see if its gone ,
ok with the glowplug fuse, but what is the similar black box in front of the battery, the 2 fan fuses? ta
yes the fan fuses. and make sure you give them a pull in the middle, mine went but it was a fine crack that opened up when warm, it was a pain in the *** finding it was the fault.
gt - thanks
but now papa's confused me, our 'glow plug power feed fuse is the small black box' is on the drivers side above the air filter
looking at your engine the glowplug fuse is on the left above the air filter it is a single strip fuse i think its 80 amp ? can't remember.
the 2 on the right by the battery are for the fans, they go into the fan controller bolted next to it, if you follow the wires its a black box with 2 plugs if memory serves me correct.
1 - 10 of 10 Posts
