I'm after a trusted workshop to take my van to be lowered. I don't want to go to some random garage that may do a dodgy job, I'd like somewhere that specialises in fitting lowering kits to Transporters. I'd like to lower the van 40mm on H&R springs and have the front and rear anti roll bars upgraded too as I've heard this makes a massive improvement to the vans handling. Ideally if the place was in the north west area and could supply and fit me the correct set up for my particular van that would be spot on. Any recommendations would be great. Cheers, Jay.
Hi Jay,
Why don,t you order up the parts you require and save yourself a few pounds,and to be honest any decent mechanic or even a competent diy mechanic can do this job. don,t see why you need a specialist to fit these components.
Jut make sure you take it for alignment after fitting.
(y) :D
As Frase say`s, get parts from say - Chillie jam vans- on line. any decent garage will be able to fit for you. its not a specialist job.
Regardless of the above posts, not everyone has the ability/access to tools such as spring compressors etc. Plus doing the ARBs can be a bit of a ballache.
So to actually answer your question, Merseyspeed come pretty highly recommended. Personally I'd also speak to AR Tuning up in Morecombe as well if you're anywhere near there. They should be able to help out.
wtf?? :ROFLMAO:
one of the above posts said...
and swapping suspension isn't hard, setting the geometry is reasonably easy also(y)
OR you could go to a van 'speciallist' & pay 'Scene-Tax':rolleyes:
Rich.
