probably sounds like a daft question but...
on a 2.5 tdi 2002 reg 102 bhp van base (not caravelle etc)
where's the ECU located as i have done the cage mod (http://www.vwt4forum.co.uk/showthread.php?t=38396&highlight=cage+mod) and want to find the main connector for the loom to ECU
the connectors i have done so far (air flow potentiometer, throttle pedal connector and what looks to be an air temp sensor on the side of the intercooler) seem to have made a difference. the engine just seems "happier":):confused: smoother running etc
and the ECU unit seems a logical connection to do - but where is it???
Not sure about this but I thought it was by the battery?
I seem to remember reading about fitting the leisure battery next to the main battery meant the ecu had to be repositioned ;)
Hope ya find it T:
Chris :ILU:
Thank u very muchly, conspiracy T:
As you suggested - down low in front of the battery
What a daft place to put it! - In a hot engine bay, exposed to the elements :GL
Would have been far better put in the cab , behind the dash somewhere.
You think thats nuts......when a m8's autobox was playing up, we found the problem was a printed circuit strip which was inside the box submerged in the boxes oil :eek:LOL:
Ya gotta luv em :D
Glad ya sorted T:
Chris :ILU:
