Hi Guys.
Where will I find the plate with the paint codes on ?
My project at the moment has no plates anywhere that I can see DOH !
Cheers mark
Cheers guys, no service books with the van. I have the cover off the fuse box do you know which code it is ?
You will probably have two lines in larger letters, the first line is vehicle type explanation. The second line is paint / interior / engine, the first 4 digits of the large block will be the paint code. As an example mine reads LL5Z00000000UF. LL5Z is my paint code (Island Blue Metallic).
Hope that helps a bit:confused:
