Can someone help me work out why someone has cut and joined these wires under the steering column of my 2005 t5?
Audio equipment Electrical wiring Computer hardware Cable Flowering plant
they have cut the yellow/green wire and joined it to the black/white wire. Should I restore it?
Does everything work ok? Possibly there was something fitted like a tracker if it’s ex commercial van?
thanks for the speedy reply!
all door modules wont unlock (this is a new problem) and i cant get a scan off my obd port (has never connected) with a cheapo reader. So whilst disconnecting a aftermarket stereo i was just looking to see if i could see any damage to the wiring loom and found this.
I should add that i have checked for corrosion on the wire under the seat and its fine / im getting 12v at the convenience module and all doors locks with central locking.
Super Moderator
That looks like the wiring mod for the head lights. The dip beam stays on when you go to high beam with caravelle twin lights.
