1 - 16 of 16 Posts
Any way at all?
They are ET17.........and are HUGE!
I've asked on another forum, but it's still 50/50.......i have twin sliders too so will need to clear them somehow.
Cheers guys
I have a set of supra 9x17 with 265/40 tyres for my van and they do fit but need a spacer fot the door, dont know they might be just a tad to much.
Am sure someone on here will know more.
Banned
they`re not split rim amg`s are they?
ive seen a set the exact size as that
sweet wheels if soT:
wondered if they would fit myself?
if you wanted the bus slammed running 17`s on a a low profile tyre you wouldnt get the right load rating
i think they would need a stretched tyre to fit aswell
making them a bit unsafe even if they did fit.
would look the dogs danglies if you fitted them but wouldnt like to use them as a daily runaround
Cheers guys.......still not sure whether to buy them...they're reasonably cheap, and they're Borbet A's, my favourite wheel:D
Ta much:)
just sold some turbo wheels that 18x11.... i know what mean HUGE...T:
thats not a good offset for something that wide if its far a T4:( unless your not planning to lower it to much or fitting arch kit);)
10x17 with an offset et50 fit well with a slight stretch on the tyres.
But et17 is going to be a struggle I reckon. Doable though.
no idea mate, but hellooooo T: just wait till the footy starts again Rasp:LOL:
Banned
i think its all about practicality
how often are you going to use your van
if its your daily then no
if its an occasional use show and shine build then do it
is your van lowered?
(prob guessing you have if you are looking at these size wheels)
wheels this wide will cause serious probs with uneven tyre wear on a lowered van
rear has no adjustment and the wider the wheel on a slammed van the worse the tyre wear will be.
inside edge will go very quickly.
not very practicle for if you use it everyday.
will cost a fortune in tyres
Discussion Starter · #11 ·
The bus isn't lowered....yet.....and they will be for occasional use only, show season really.
I'm determined to get them on somehow, but they will no doubt catch on the sliders, will they catch on the inside too, i suppose i can space them a bit....
Whatever happens, i'll have them and give them a 'furb, if no good, i'll bung 'em up for sale again.
Cheers guys........and hello Mick, surprised they let 'your sort' on hereRasp:
the only probs you will have is with the et 17 catching on the slider but they will look great
.i run 10x18 et35 with no probs at all
cheers
higgy
Banned
you will def not be able to open sliding doors
my wheels are 8.5j on et35 and the door just slightly rubs when opened.
your wheels you are interested in will be about 2" wider maybe a little more.
you can get projekt zwo spacers for the door though if wanted
there should be some info on here if you search for it with a link to a site to purchase them.
Banned
cheers for pic mate looking good
ive got 8.5j et35 rims and keep thinking of getting 20mm spacers for the rear.
i think i will after seeing pic the rear wheel sits perfect with arch there
ive got a swb and need to sort sliding door though
looks sweetT:
1 - 16 of 16 Posts
