you will probably need spigot rings as and you might need to make the bolt holes larger as i think merc use 12mm bolts and VW are 14mmT:
should go straight on with spigot rings,i have read recently some merc wheels have a 12mm stud hole and transporters are 14mm,but its just as simple as running a drill through them,i have merc clk rims on mine,straight fit no hassle,only thing is i still have to get spigots as you would have too much fiddling trying to change a puncture at the side of the road
