If your window is actually startling to come away, then I would seriously consider having them all taken out and rebonded properly by a window specialist. It will probably be necessary to clean off whatever bonding is failing and then re prime and bond using correct window adhesive. A leak is one thing, but bond failure could be dangerous if you lose a window at speed.
