Hi
I have a 1998 t4
I’m looking to remove the glass at the rear sides to fit black out film. Has anyone done this. I could do it on my older van I had as it had a rubber gasket which you pulled out then the glass was pulled out after this. The glazing system is different on this year so looking at any tips/advice.
thanks in advance
Scott
Full of Cr*p....
You need a "cheese-cutter" wire device to cut through the bonding.
Easily available on ebay as a kit with all the tools needed.
Can't you do the film without removing the glass....that's how most pro people would do it.
Clean, clean and clean again....then oversize the film, apply and CAREFULLY use a scalpel to trim to shape.
