hi guys can anybody help ? i have a 2002 2.5 tdi and every time i hit a good bump which is quite oftern with pot holes around where i live the wipers do a full wipe and also started to do it now and again when i use the indicators .is it the wiper controls or have i got electic gremlins starting with van .:*
No deff answer I'm afraid. It could be several things. Start with the cheapest and check the wiring from the stalk switch to the fuse box. Check the loom in the engine bay where it passes under the brake servo. If you can't find anything there try changing the relay number 19.
