Wiring in Sony xav ax1000 to my T4
1 reading
5.6K views 5 replies 3 participants last post by  DuncanE
#1 ·
196444
J
196445
I’m having trouble wiring in my Sony xav ax1000 it looked like wiring harness was very similar match from the kenwood stereo I was taking out. Plugged it in but absolutely nothing. Any help would be greatly appreciated. Ps. As you may tell I’m not overly electrically inclined very basic knowledge
#6 ·
Check the fuse on the back of the stereo just in case.
Aside from that you should use a multimeter on the power wires to see if it's getting 12v. Test Red to black and yellow to black with ignition on
Aside from that you should use a multimeter on the power wires to see if it's getting 12v. Test Red to black and yellow to black with ignition on.
Hi. Yes I’ve checked that all good. I’ve managed to get it working. Was weird I had to take small piece of wire to connect from yellow to red as was done on the kenwood stereo I’ve taken out. So great. Got it working. Problem now is can’t turn it off. Ignition off but head unit still on. Had this with the kenwood stereo but I could manually turn that off I can’t do that with this Sony head unit so I’m a little stumped there. I can only think there’s some wiring done a little wrong in the loom behind the dashboard
