Hi
Ive got hold of some fog lamps for my t5 2008
ive also just bought a replacement light switch with the extra turn for front fog option
i now need to make up a wiring loom or can the llom be bought
if not can someone tell me what i will need and how to make one up
steve
I did another conversion at a dealers yesterday on a 2011 model and will post part numbers later for what is needed when i get back
Here is whats needed
7E5 807 490 A GRU RIGHT FOG LAMP TRIM IN PRIMER £19.83
7E5 807 489 A GRU LEFT FOG LAMP TRIM IN PRIMER £19.83
7E0 941 699 A LEFT FOG LIGHT £45.33
7E0 941 700 A RIGHT FOG LIGHT £45.33
7E0 971 114 AG FRONT LOOM (BEHIND BUMPER) FOR VEHICLES WITHOUT FACTORY PARKING SENSORS £59.63
1J0 973 835 FLAT 10 PIN HOUSING (NEED TO MAKE OWN LOOM) £2.73
000 979 219 CABLES FOR THE ABOVE 10 PIN HOUSING (2 WIRES NEEDED GIVES YOU 4 CONNECTORS) £2.72
6Q0 941 531 N 20H LIGHT SWITCH STANDARD BLACK COLOUR £74.87
when making the rest of the loom to go from the flat 10 pin connector you will need a relay and connector like below to go into the correct place at the back of the light switch (white/red position)
http://www.ebay.co.uk/itm/10-x-2-8-Timer-ISO-Female-Receptacles-Connectors-M-55-/200689989399?pt=UK_In_Car_Technology&hash=item2eba0e3717 but you only need 1 for the switch
