Hi all got the lights to wire on my facelift, anybody got clear instructions for the mullti plugs on a normal 5.1 headlight, I have atool to remove the connections just need to know where they all go:*:*
If you trawl through jays thread on fitting a facelift in customising section... It's all in there. If you have DRLs there is a bit of wiring behind the dash to do to.... You will need a soldering iron / solder and some heat shrink too. After watching festa do mine on Sunday, IDE say its not that straight forward as you may think... Mind u I am from Essex :D:D
