1 - 12 of 12 Posts
Hi all, have you ever used the wheel Fitment Guide on the Wolfrace website?
It's a comprehensive tool that can be used to find out which wheels from the Wolfrace range are available to suit your van, better still - it's now available to use within the vwt4forum.co.uk pages!
The guide has been embedded within our Trade Plus section here: http://www.vwt4forum.co.uk/showthread.php?t=368420
Currently you can use the tool to search our stock and see what wheels fit your VW Transporter T4 or T5 - we're working on adding the very latest gen T5 as we speak.
Here's a quick run-through of how it works:
Step 1: Select either T4 or T5 from the drop-down list.
Step 2: Select a chassis type from the list - it actually doesn't matter what you choose on this step as the results won't alter.
Step 3: Select your preferred wheel size. The list shows the maximum wheel size available from Wolfrace for the vehicle according to Driveright and TUV data.
The results page includes original equipment data for your chosen vehicle - year of manufacture, PCD, offset, front and rear centre bore, fittings specification and o.e tyre size.
A NOTE ABOUT TYRES: THE GUIDE GIVES A TYRE OF 255/35/20 - WE ACTUALLY RECOMMEND A 275/35/20 TYRE AS IT GIVES THE BEST WEIGHT LOAD.
Available wheels are displayed with brand and wheel name, product code, alloy wheel size, tyre size, warehouse stock (UK) and factory stock.
Where a wheel has factory stock but no warehouse stock, the wheel would need to be ordered specially (normally from Germany). Your local Wolfrace dealer can give you lead times.
Any product that is shaded in grey is currently not available.
We have a lot of stock deliveries scheduled over the next couple of months so the likelihood is that you won't have to wait too long for your favourite design to become available.
If you have any questions about the guide or the Wolfrace wheel range please feel free to message me, or contact your nearest Wolfrace dealer several of whom are on here!
Visit our our Trade Plus section and give it a try.
Hi, I've had to have front passenger side repaired due to pot hole damage.. Now wanting to put on e drivers side, what will tork wrench be? Thanks Gail
Bit disappointing that the nut cover/wheel centre things spin on my wheels, wolfrace don't want to know, usual stealer, "never seen them do that before" attitude
As I say disappointing, any one else had any issues?
Looking at the genesis 20 inch on a 2015 T5, still don't understand offset etc! What size would be best? Van will be low on bilstein coilovers...
What would be the correct torque setting for the wheel bolts on 18" Wolfrace Eurosport Turismo fitted to a LWB T5(T30)?
Thanks,
Gareth
Hi there would like to ask a question hope it's not to stupid .is it better to fit genuine vw wheels to my 12 plate t5 as they will be the right weight and ride quality
Discussion Starter · #11 ·
Not necessarily - our wheels are drilled and machined to the correct offset and pcd for your vehicle and we only display wheels on our fitment guide that have adequate weight load. T:
1 - 12 of 12 Posts
