Hi all, have you ever used the wheel Fitment Guide on the Wolfrace website?
It's a comprehensive tool that can be used to find out which wheels from the Wolfrace range are available to suit your van, better still - it's now available to use within the vwt4forum.co.uk pages!
Currently you can use the tool to search our stock and see what wheels fit your VW Transporter T4 or T5 - we're working on adding the very latest gen T5 as we speak.
Here's a quick run-through of how it works:
Step 1: Select either T4 or T5 from the drop-down list.
Step 2: Select a chassis type from the list - it actually doesn't matter what you choose on this step as the results won't alter.
(Sorry i know this example is for T5!)
Step 3: Select your preferred wheel size. The list shows the maximum wheel size available from Wolfrace for the vehicle according to Driveright and TUV data.
The results page includes original equipment data for your chosen vehicle - year of manufacture, PCD, offset, front and rear centre bore, fittings specification and o.e tyre size.
A NOTE ABOUT TYRES: THE GUIDE GIVES A TYRE OF 255/35/20 FOR TRANSPORTER T5 - WE ACTUALLY RECOMMEND A 275/35/20 TYRE AS IT GIVES THE BEST WEIGHT LOAD.
Available wheels are displayed with brand and wheel name, product code, alloy wheel size, tyre size, warehouse stock (UK) and factory stock.
Where a wheel has factory stock but no warehouse stock, the wheel would need to be ordered specially (normally from Germany). Your local Wolfrace dealer can give you lead times.
Any product that is shaded in grey is currently not available.
We have a lot of stock deliveries scheduled over the next couple of months so the likelihood is that you won't have to wait too long for your favourite design to become available.
If you have any questions about the guide or the Wolfrace wheel range please feel free to message me, or contact your nearest Wolfrace dealer several of whom are on here!
Visit our our Trade Plus section and give it a try.
To be honest i have no idea why it lists 'T4 Caravelle' five times! must be something to do with chassis, as mentioned though this makes no difference to the results.
Just did some test on T4 15" wheels and 19" wheels and it worked fine (PC, Firefox) see screen caps below.
I'll do some tests on ipad and Mac and see if i can get that sorted.
Hi all my caravelle standard tyre should be 205/65/15 with load rating of 100
Does the same apply for winter/ snow tyres, we are off to the Alps next month I want not only the best snow tyres for the job but also the correct load rating and size.
Do vw recommend a different width for snow...
I have a T4 Caravelle X plate Yr 2000 and am having problems with wheels. I was on holiday a couple of months ago and hit a pot hole that damaged my alloy wheel beyond repair and have been looking at ebay every couple of days to match up without any luck. The alloy wheels I currently have are 18...
Does anyone have a set of banded steel wheels for a t4
I have either a set of Calibre 18 inch alloys in Black (two of the tyres are new)
a set of winter wheels 17" with new tyres
or a set of ATS Deepdish Rims 4x100 (For a mk1 golf etc) if anyone is interested, will upload pics later.
Ideally...
My friends I have a problem. I will show You my Multivan, it is lowered -40mm, and I want to change rims in it. I have bought DOTZ LAS VEGAS as on pictures 18x8H2, and now I am considering what tyres will fit. I must say I would like to have as much tyre profile as possible, and I know, I should...
