1 - 20 of 55 Posts
Updated Workshop Clearout
Right i am acumulating far too much stuff as my project moves forward so here goes:
  • Front subframe from a 2002 T4 van £50
  • Front lower wishbones from a 2002 T4 VGC £25 EACH
  • Front upper wishbones from 2002 T4 VGC £25 EACH
  • Pair of rear ABS sensors from a 2002 multivan with built in looms for pad sensors £35
  • Rear wishbones L&R from 2002 Multivan with ABS pole rings good brgs&bushes £40 EACH
  • Long front bonnet needs some filling and paint £15
  • Front grill complete good condition will require paint £20
  • RHD 2000 (not AC) heater box matrix not included £10
  • Heater blower motor (not AC) GWO £20
  • AC evaporator for LHD Climatronic w/rear climate £50
  • Radiator and fans good working order £20
  • Complete set of radiator hoses good condition £15
  • Caravelle rear load space carpet in grey good condition £25
  • Headlining panels in grey for SWB panel van with no bulkhead £15
  • Caravelle rear interior lamps pair £20
  • Pair of standard window regulators GWO £15
  • Tailgate heated glass no tint £15
  • Pair of front door glass's no tint good cond £20
Thats all i can think of for now if you want any pics please let me know i will be able to post some items but collection would be prefered on the glass and bigger items.:ILU:
i'll take the electric window regulators if these will fit my 03 plate t4 if not can you tell me what the difference is.
where abouts are you?
excuse my ignorance but i have an eletric regulator fiitted and it has 2 wires plus earth coming from the motor what difference can there be it's an after sale fitting(by previous owner so it would not nesessarily be wired like a 03 original can you or anybody help me my motor is fine it's just when my van was broken into the cable became kinked would it be possible to change the cables? if you don't know any of the above would you take £50 posted to derby for them?
Discussion Starter #14
Hi,Interested in the Rad hoses if they are off a 1.9 td (1998):)
The hoses are for a 2.5tdi i dont think they are the same.
where about in wilts are you? Interested in slide door glass, my wife is in Salisbury tommorow!
Im located in westbury altho its probably abit late now.let me know if you are still interested.
how thick are the t4 to porsche adaptors?
The adaptors are 25mm thick.
hi there im new on here
im looking to take my t4 van to about 155bhp
wil these parts help
Project Power injector nozzles brand new £150
AHY 150 BHP engine inlet manifold rarely seen in uk better air flow to engine £155
AHY 150 BHP engine exhaust manifold rarely seen in uk allows the use of 4 bolt flange garret turbos £135
AHY 150 BHP engine EGR valve £50
thanks david
Discussion Starter #18
thanks david
Hi wiley, Yes these parts will go some of the way towards 155 bhp its not all direct fit tho pm me your number and i will give you a call to explain better.
James
1 - 20 of 55 Posts
