hi there
i am possible after a gearbox for mt t4 ajt 2.5 tdi
there is no 5th gear
i have read on here that this could be an easy fix but i am poreparing myself for the worse so if any one has a gearbox lying around please give me a shout
or
if they have the parts that i will need to sort 5th gear out,
unless it has undone and come of like i thinmk i have read
hope some one can help
location is camberley in surrey
thanks in advance
cheers
Adie
Have you considered replacing the 5th gear with the lower ratio kit?
Approx £160 for the parts
hi mate
thanks for your post
i would concider this once i have got the gearbox out and the end plate off so i can tell if its just the 5th gear or worse
have you changed a 5th gear at all?
coiuple of questions u maybe able to help with buddy
1. once i have the gearbox out, how will i be able to tell if i have an easy fix or a harder one(replacement gearbox)
2. do you have the part numbers that i would need for the taller 5th gear mod
3. is the ruff figure u have quoted for dealer original parts or 2nd hand parts from other vw g/boxes
that will do for now,
dont mind a pm if u wanna take this off line and have the time bud
thanks again
hi mate
No, but there's a comprehensive guide somewhere on this forum and it can't be that difficult
You don't need to remove the gearbox - refer to the guide on this forum
Numbers listed in the guide
Original VW parts - new
in short, refer to the guide, its definitely worth a look
hi buddy
i did a bit more searching and found the guide you are talking about. there is quite a fww threads that mention the 5th gear mod and it was a little confusing.
i wanted to make sure that i order the correct gears etc
once i get the van i will take the end plate off and see whats what
do you or anyone know the other damage that can occur to give no 5th gear at all
does the 5th gear actually come off/loose or something?
cheers
Adie
