Hi there,
Very much out of my depth with this question so apologies in advance for any faux pas etc.
I purchased a 1994 VW Transporter fully kitted out and since purchasing and having trips out have noticed that the Waeco fridge keeps cutting out and then starting back up again. The more trips we took the more apparent this became, and last weekend when we were hooked up to 230v I got the multimetre out, took the fridge out and ran some tests...
The voltage reading to the fridge kept dropping every 30 seconds or so causing the fridge to cut out and effectively reboot. The zig unit battery condition would go from green to red every time this happened (only momentarily) if the lights are on at the same time this caused them to flicker (again, only momentarily). The fridge would then power for 50 seconds and the same would happen again on repeat.
When the Waeco fridge cuts out the led above the power button inside the fridge goes from blue to orange with a red flashing light above the orange LED (a Google search told me this means there is a voltage drop). We tested the wires running to the fridge behind the unit and there was infact a voltage drop to the fridge (I cant remember the exact readings).
I coudnt solve the problem on site so we continued without use of fridge and drove home on the Sunday (45min trip).
The next morning I checked the leisure battery (12v AH (20h): 75 amps) with the multimetre in idle and got a reading of 13.4v (presumably the engine charged the LB when we travelling back the previous day). I then went to the Zig unit, flicked 12v on, and the touring/on site rocker switch to 'on site' I then turned on all the lights, the fridge on full power and the fridge power LED was displaying blue. I checked the LB voltage and got a reading of 12.4V. I should mention at this point im on the drive and not plugged into mains hook up, this is all on 12V. Everything ran perfectly. I then switched the zig unit from 'on site to 'touring' this (for me) kicks my solar panel into gear and the solar control unit lights up indicating sun is available but my battery is near empty (red)... personally I wouldn't say 12.4v is near empty... Anyway, I did this to see if the solar panel would provide power to my leisure battery to manage the pull from the 6 LEDs and the Waeco fridge (otherwise it would overtime just run my LB flat). Everything worked perfectly for 1st hour and 2nd hour. On checking the 3rd hour, this is what I opened the door to...
The Waeco fridge kicks in (blue), LED lights flicker and takes LB down to 11.7V - solar panel displays red flashing (voltage drop) and zig unit battery condition goes from green to red. This lasts 36 seconds. Then fridge stops and LB goes to 12V - solar panel displays yellow (low). This lasts 50 seconds and then the process repeats.
If anyone can shed any light on this I'd be massively grateful, like I said I'm way out of my depth hear so go easy on me.
UPDATE: After running the above tests my LB was reading 12.3 with everything turned off. I kept the zig unit on 12v and flicked to touring to keep the solar panel running. (The solar panel displayed the battery as green steady which means normal). I rang some people and wrote this discussion and just went to check my LB reading again - im getting 12.6V now so hopefully that means the solar panel is working how it should and charging the LB.
I think it's something to do with this Zig CF8 unit but what do I know!
