2.5 tdi acv engine mounts problem
1.6K views 3 replies 3 participants last post by  T4COXY
#1 ·
Hi people need a bit of info regarding engine mounts on a 2.5tdi acv ive changed the pendulum mount and o/s engine mount but still have a big vibration and the occasional squeek which i think is the ceramic o ring in the exhaust moving when the engine pulls under load ive tried to locate a new n/s mount on ebay and through google images but no luck is it a main dealer part i know euro parts dont list it. It also has a large bracket running through the center with a smaller rubber mount at the top any light shed would be appriciated also is there anything else that could cause this type of vibration its noticable on tick over but worse changing gear :(
#2 ·
Main dealer part im afraid.
Dual Mass Flywheel would be the big culprit, closely followed by the vibration damping pulley on the crankshaft.
New injectors helped mine too, the old ones were causing very lumpy running. Injectors are life limited.
