It seems, a lot of people on here go for the full on, home from home luxury conversion with every device known to humanity. Don't know if it's just me, but one of the things I like about a bigger vehicle is haveing versatility.
So when, after 11 years and 120K miles Newton the t4 was getting longer in the tooth than was good, I decided to upsize to a Crafter. It didn't help that we have just aquired custody of 4 and 5 yo grandchildren, which ever way you looked at it, Newton just wasn't big enough.
But which Crafter? Going the full monty LWB hi roof was tempting, however, we like to cross the pond occasionally and I remember from previous experience you can end up paying a lot of money to basically transport air on a ferry.
So a MWB with a low ish roof would be a preferred choice. At least 4 belted seats a must.
Being a bit old fashioned I thought that 2L isn't really a lot to shove that around so I was looking for the old 2.5. Further research suggested the later itterations as they came with higher final gearing
From experience I was drawn to ex Police / Ambulance vehicles as a lot of the donkey work has been done for you.
Cutting a story short I settled on an ex GMP 2010my CR50 135hp support vehicle, 9 seats MWB intermediate top. A nice factor is the proper sealed hard floor that means you can clean up after a long trip with the boys by simply driving it up on ramps. opening both back doors and blasting all the debris out with the pressure washer!!
All the interior lining is already done, side windows are a sort of shatter proof perspex whihc means if it starts getting very lively you can hide in the back. If its getting very lively you can hunker down as the internal panels are all done in Kevlar which gives a level of balistic protection. Did I mention I do festival security in the Summertime??
The front half of the back body had 6 seats on unwin racking, 3 of which came out striaght away, the other three can be removed in a few minutes using a 17mm socket and my big cordless. Already it has prooved it's versatility moving a Land Rover engine which was simply ratcheted down to the racking and 11/2 tons of compressed fire logs in 3 1 ton bags which, with all seats removed fitted easily in the back.
i've previously noted issues I had getting a sound system to work, that was easily solved by installing a second battery under the passenger seat with 200W of solar on the roof through an MPPT controller. Has an added bonus that I won't need to worry about having the music on when parked as it will never ever result in a flat vehicle battery.
The management wanted a proper double bed in the back, this was a bit of a head scratcher, if i wante to be able to continue using it as a van. The problem was solved by building a couple of frames on the sides of the van with another removable frame up the centre line. Then purchase a couple of sheets of decent ply cut them to size, put them on hinges to the outer frame and bung a mattress on top and, presto hey!!! Yeah I know, I need to photograph it all, best go off and get my camera....
Anyway thats us, so far so good,.
Rhys
Rhys
