Advantages and disadvantages of Bluemotion?
6.2K views 6 replies 6 participants last post by  MikeyB99
#1 ·
I am learning about T5s to source the ideal van for a camper conversion, can anyone explain what are the good and bad points of blue motion variant?
Grateful for all the help I have received so far, this is a new and exciting world!
#2 ·
In my limited experience, anything thats good for the environment is bad for the engine, its the same across the board with all makes and models but particularly diesels. What you will save in tax you will pay for with expensive DPF filters failing and EGR valves clogging up plus whatever else they add to modern vehicles to strangle all the life out of them.
#5 · (Edited)
Hi Polly
If new ( T5.1 / GP ) i'd go for the 140 or 180 with a 6 speed box as your camper is likely to be heavy
if looking at older T5's vans this would mean a 130 / 174 but the newer vans probably do 5 mpg more if driven sensibly and the 5 cyl engines can be expensive to work on.
i've got a 114 bluemotion The stop start is good as are the low rolling resistance tyres and the cruise control. fuel economy excellent ( 43mpg ). unfortunately 4th and 5th gear is a bit long in the Bluemotion. Ok if you are lightly ladened but you would find yourself in 4th alot on the motorways.
Unless you are buying a much older vehicle ( pre 2005 ) then all the engines comes with EGR etc to comply with the emissions so you cant escape these features.
Hope this helps
