Coolant capacity
1 reading
24K views 11 replies 6 participants last post by  rdfrnplrdfrn
#1 ·
I want to drain the coolant from my 2.5TDI ACV lump and refill with recommended anti-freeze mix.
2 questions :-
Is it advisable to use VW specified anti-freeze
What is the coolant capacity so I know how much to buy for a 50/50 mix
Thanks:*
#2 ·
VW say only use G12 A8D or Spec TL-VW 774 CD otherwise corrosion damage can occur.
Normally supplied by VW as pre-mixed but antifreeze must be 40% minimum.
G12 is red, if brown then it has been mixed with another product
9 litre capacity for basic system, more if extra heaters fitted.
