Started the van up and drove it a short distance , stopped the engine and then restarted it , immediately there was a large rattle and smoke from under the bonnet ?. The smoke was coming off the timing belt , obviously there was something rubbing on it . Had a look underneath and the only conclusion I can come to is the vibration damper has failed . If you put a bar behind it there seems to be a fair bit of movement and it does look like its touching the belt . Am I right or is there something else it could be . Is this a common problem and how easy to rectify
Cheers marcT:
Cheers marcT:
