301 - 320 of 497 Posts
Discussion starter · #301 ·
The new adjusters for the PZ lights only just arrived before I had to go a few weeks ago. I've managed to put it all together now with a new section insert to replace the motorised adjusters which I don't have. I also ordered some golf adjusters which work with the M5 riv-nut for the dipped adjustment arm.
Discussion starter · #305 ·
Also in the process of fitting, there was a handy thread on the Facebook ProjektZwo group showing the jumper under relay 53 to keep both the main beam and dipped lights on at the same time when on the main beam. Apparently some folk won't have relay 53 if you don't have the factory fitted front fogs (FFFF's). I had some long spade crimps and bent them so they allowed the re-fitting of relay 53. (its the two spare slots that the relay doesn't use).
Discussion starter · #307 ·
courtesy of my good friend Mr Breckon. He's managed to fit my new second hand ARB awning. It was destined initally to adorne the side of a certain Mr Proctors Managon style overland truck but he got shot of it and I got hold of this never used.
These are the ARB brackets off ebay. Sturdy bits of metal indeed that required a little fettling to get them to fit as shown:
Discussion starter · #309 ·
Treated Syd to a new digital speedo and inclinometer from CamperVan Culture. Not the cheapest bit of kit but its really handy. Daft **** here can't see the speedo properly through the steering wheel sometimes to this makes it a little more comfortable. (ignore the angle of the headlights, that's a work in progress)
