Hi, after spending a lot of time researching and viewing this forum for info and advice I finally think I have something to share. I just hope I get this post right: I had spent a long time searching for a van to use for work and leisure, I almost gave up after looking at loads of vans mostly were overpriced and in poor condition. Anyway, I finally bought a silver T5.1 shuttle from a really nice guy who used it in his travel firm. High miles but well looked after. It had a few marks on the body, but apart from that it was in really good condition and the price was right!
The first thing I did was to remove the rear passenger seats and replace them with a California seat/bed on rails.
You can see I kept the original interior trim but have replaced the carpet with a rubber floor, this because I wanted to utilise the window blinds built into the trim and save the cost of rebuilding the interior. I have put silent coat and insulation on the panels behind the trim and under the floor, I’ve also put a layer of under tile insulation directly under the rubber floor covering, the result is a bit like cushion flooring. Why a rubber floor? It’s easy to clean!
I will continue a bit more hopefully tomorrow.
