Hi Guys,
I recently picked a 2005 t5 174 axe for what I was hoping was a bit of a steal and an upgrade from my T4. The previous owner had an intermittent starting issue, where after turning the key it would:
1. Not prime the fuel pump
2. Not glow the plugs
3. Show the ASR light
4. Start the radiator fans after a few seconds
5. Crank but not start
Turn the key off and on several times and it would prime the pump and start. It got to the point where he was turning the ignition on and off for 20 minutes to get it to start. He narrowed it down to a faulty ecu, put it in the too hard basket and parked it up.
I bought the van hoping that I’d just need to fit a replacement ecu. I bought an ecu from a wreck, made it into a clone of the original ecu, plugged it in and it didn’t change anything. I’m not convinced that the ecu is at fault and I’ve confirmed that the ecu I bought was from a running wreck. On a side note, there doesn’t seem to be any info on cloning ecus for the T5 on this site, thinking I should put a guide together (That's if it doesn't eventuate that me cloning the ecu caused the problems
Doing a scan with VCDS brings up a lot of no communication with Engine Control Module faults:
I’ve only managed to get the ASR light to disappear once since getting it home and, on this occasion, I had a full connection to the ecu. Unfortunately, this was before I really knew what was going on with the van and didn’t take advantage of it. I Didn’t even record what codes were read from the ecu…
Now this is where I start to go down the rabbit hole, testing anything and everything that I can think of. In the end it's probably just going to be something simple.
The ecu is switching the 109 relay when the ignition it turned on but it doesn’t seem to be doing much more than that. The fuel pump and glow plug relays aren’t switching because the ecu isn’t switching the ground for those relay coils. I’ve checked the power to the ecu, albeit with the plug not connected to the ecu, and I get 12 where I should, and it seems to have a good ground. Thinking now that I should try and measure the voltage with it connected to the ecu.
Here’s the pinouts for the ecu, pin 18 is supplied with 12V when switching on the ignition. This triggers the ecu to switch pin 49 to ground, which closes relay 109 and powers up the ecu fully from pins 3, 5 and 6.
Neither of the ecus are dead, I can still connect to it with VCDS, I just can’t read any of the actual fault codes from it and my flash tool can read and write on both. I found that on the pre-facelift T5s VCDS works on the diagnostic wiring (K-line) rather than canbus. So I thought it must be a canbus fault.
I started looking at the canbus wiring and doing some testing with a multimeter. I got a resistance of 66 ohm between can-high and can-low - which is the resistance that I should be getting, based on what I’ve researched. This is measuring at the instrument cluster connector. Disconnecting the ecu and the resistance increases to 1 kohm or more. This tells be that the wiring between the instrument cluster and the ecu is ok. Measuring the voltage of can-high to ground and can-low to ground both measure about 2.5V. I was expecting a voltage differential of about 1V between can-high and can-low but I guess that’s only if there is data being transmitted. I’d need an oscilloscope to do any more testing here… Maybe there is a faulty module disrupting the network?
I also thought it may be an immobiliser fault. Just to check I dismantled the key and turned the ignition on with just the blade of the key. I got a flashing immobiliser light, which I wasn’t getting before, so this must be ok. I’m guessing that the instrument cluster must do some kind of initial check for the immobiliser, otherwise there would have to be communication to the ecu?
So, I’m here looking for suggestions on what I could try next because this has turned into a bit more of a saga than I was hoping! Currently I’m working on powering an ecu on the bench and attempting to read the faults via the K-line directly. If this works maybe I have a poor 12V supply or ground to the ecu that isn’t allowing it to boot up fully? I’m still curious why VCDS will connect to the ecu but not read any of the faults from it. After this I'm not quite sure what else to try before tearing the loom apart and throwing parts at it!
Sorry for the long winded first post, just thought that it would be easier if I could cover everything that I’ve looked at.
Code:
Tuesday,01,January,2019,20:12:14:45847
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.2 (x64) HEX-V2 CB: 0.4437.4
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZ5H054XXX License Plate:
Mileage: 131270km-81567mi Repair Order:
Chassis Type: 7H (7HA - VW T5 2005)
Scan: 01 03 08 09 15 17 19 46
VIN: WV1ZZZ7HZ5H0XXXXX Mileage: 131270km-81567miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 070 906 016 BD HW: 028 101 183 5
Component: R5 2,5L EDC 7001
Shop #: WSC 02756 785 00200
VCID: 53F38188F7EE79EF737-5184
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 03: ABS Brakes Labels: 7H0-907-37x-ASR-F.lbl
Part No: 7H0 907 379 G
Component: ASR FRONT MK25 0103
Coding: 0007205
VCID: 392FD3207542A3BF99B-513C
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 7H0 820 045 R
Component: CLIMA/AC 0202
Shop #: WSC 00000 000 00000
VCID: 3431E21452205ED74AD-513C
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
013 - Check DTC Memory
Address 09: Cent. Elect. Labels:. 7H0-937-049.lbl
Part No: 7H0 937 049 K
Component: BORDNETZ SGVER 1.0 1901
Coding: 0000101
VCID: 3A2DCC2C7044A8A7901-513C
2 Faults Found:
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
008 - Implausible Signal
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 A
Component: 3C AIRBAG VW51 0008
Coding: 13123
Shop #: WSC 02756
VCID: 221D144CFDD4C067A81-513C
1 Fault Found:
00588 - Airbag Igniter; Driver Side (N95)
32-00 - Resistance Too High
Address 17: Instruments Labels: 7Hx-920-xxx-17.lbl
Part No: 7H0 920 850 G
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 03702
Shop #: WSC 00280
VCID: 2E05F07CB90C74073C9-513C
WV1ZZZ7HZ5H054688 VWZ7Z0D1043099
1 Fault Found:
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 02756
VCID: 70B92E0463B822F76E5-513C
1 Fault Found:
Address 46: Central Conv. Labels: 7H0-959-433.lbl
Part No: 7H0 959 433 B
Component: C2B Komfortgerát 0004
Coding: 00069
Shop #: WSC 02756
VCID: 323DE40CAD3450E7581-4B1E
Subsystem 1 - Part No: 7H2959802
Component: Tõrsteuer.FS KLO 0203
Subsystem 2 - Part No: 7H2959801
Component: Tõrsteuer.BF KLO 0203
4 Faults Found:
01362 - Close Switch for Tailgate/Trunk (F124)
29-00 - Short to Ground
01331 - Door Control Module; Driver Side (J386)
53-10 - Supply Voltage Too Low - Intermittent
00932 - Electric Window Motor; Drivers Side (V147)
62-00 - No or Incorrect Adjustment
01332 - Door Control Module; Passenger Side (J387)
End----------(Elapsed Time: 01:12, VBatt start/end: 12.1V/12.1V)-----------
