I had issues with my drivers door lock actuator as it was sticking, not opening all the time, and I had the following error in VCDS:
01031 - Central Locking Key Switch; Driver Side; Unlock
27-00 - Implausible Signal
I also had some weird symptoms with hazards going off randomly on the drive (may be related, may not).
Anyway, spent the day on Sunday replacing the drivers lock actuator (genuine vw actuator, really nice fun job, cough, cough).
On testing, the lock works with the remote fob great so it's fixed the sticking issue as it was intermittent before. But when I use the key in the lock, it will lock and then open again straight away. If I lock with the fob and open with the key the alarm goes off when I open the door.
Checked VCDS and the same error is still there, and comes back straight away after clearing:
I've disconnected the battery for the time being and I can lock the doors with the key no problem.
Unfortunately, with the faulty actuator, I never tried locking with the key, so I don't know if this is a new issue or not since fitting the new one (although unlikely its another faulty actuator).
