The first 3 settings on my T5,blower are not working only works on the 4th setting,any ideas,ill near to source some ear plugs shortly,
The problem with the blower was the metal wire was bent and needed to be adjusted.QUOTE]
I suspect that this problem will re-occur in the not so distant future as it's a common fault (design fault that is), have a look at this thread http://www.vwt4forum.co.uk/showthread.php?t=144167 for further details.
Any chance you could post up the part number and the approx cost just for future reference..please ?Guys
I thought I'd let you all know.
I bit the bullet and ordered a new resistor pack form VW.
Thermal Resistor Pack - #VWE0 959 263 ÂŁ33.19+vatAny chance you could post up the part number and the approx cost just for future reference..please ?
hi, what were the symtoms of cam going?Dear 8tomblaster, just had to write to thank you for posting such a detailed fix for this (quite common) fault which I suffered 2 x days ago on my 2007 mdl T5 LWB 130 Shuttle. I bought 2 x of these little fuses, and yes the 240 is the blow temp in C. Done and finished in an hour. Total cost ÂŁ1.68. I also greased up the motor bearing as well as I could. A day before the failure I did hear a slight squeaking from the motor (well I think it was the motor, but it might have been a very hot resistor pack - do they make a noise?). Anyway, the fan speed control failed within 24 hours of the first squeak.
Just for interest my Shuttle has now covered 267k miles. If any one needs help with the following, I might be able to help - because I had them all replaced;-
waterpump
oil cooler x 2
cam shaft and all followers
rear wheel bearings
auto gearbox (ouch!) at 205k
turbo
exhaust manifold
exhaust gas return valve
air mass flow meter
Particulates Filter (ouch again!) at 250k
O2 sensor
lower suspension bushes
But she still looks like new !!
Thanks again
Tony
