21 - 33 of 33 Posts
I had two vw t5 .both with exactly the same problem.fan will only work on the 4th speed .
first one I fixed with replacing blower motor brushes and the second van I fixed by replacing little resistor 89 p from maplin
All thanks to this forum
so thank you guys for spending your free time to post your problems here and show us how to fix it
OK guys I really need help here. I have a T4 with airconditioning and the heater resistor seems to have blown. (I can only get the fan to work on setting 4.) I have found where the heater resistor fits on a normal t4 blower but mine is different and its not where you would expect it to be. Are there any T4 GURUS our there who can point me in the right direction?
WOW - great post! Going to get the spares ordered up.
Just 1 question if I may - where is the resistor pack on a bog standard T4 for the normal dash fan (not the velle rear fan)?
Cheers :ILU:
Sorry its a bit late. If you go behind the dash where the blower motor is, to the right hand side there is a metal plate with a 4 wire plug. It attaches at the bottom with a single screw
Cheers :ILU:
Cheers :ILU:
A bit late but it's up behind the glove box on the right hand side of the motor. There is a metal plate with a 4 pin plug and is held by one screw at the bottom.
21 - 33 of 33 Posts
