Introduction
This is a summary of
https://www.redlineforums.comTHREADs
The 88bhp (AJT - Blue I) engines are essentially identical to the 102 and the 150 except the injector specification, the intercooler and the engine mapping.
Charge air coolers increase the efficiency of engines under high sustained load by increasing the density of the air entering the engine - offsetting the heat from the engine bay and the heating effect of the compression in the turbo (about 1 bar after a remap). This puts significantly more oxygen into the cylinder and giving a bigger bang with less fuel.
This modification will not do anything at low speeds or low-boost conditions and will be pretty marginal without the other upgrades.
The is no need to increase airflow as this is only relevant at speeds over 20mph and therefore the ducts will supply adequate cooling.
There is no change to any mechanical systems so it will have no effect on engine revs at a particular speed - 5th gear mods are available.
Layout
This is the basic layout we are aiming for in both Long and Short nose version.
This version eliminates the sensor pipe shown right and connects the I/C directly into the original elbow on the inlet
Things you’ll need
1 - Mitsi Intercooler (Pajero, L200 others - source ebay/scrapper)
4 - Anti-vibration mounts - M6 (ebay)
M6 fasteners and washers
Brackets and Ducts
No code has to be inserted here.
Damping Clip - 701863841
Pipes (starting at turbo)
A - 54mm 90 elbow (original)
B - 45mm straight (comes with cooler)
C - 45mm 180 silicone elbow (ebay) - cut short on the IC end J-shape
D - 45mm 180 silicone elbow (ebay) - cut short on the IC end J-shape
E - 54mm 90 elbow (original)
Couplers
A-B - 54-45mm Alloy reducer (with flanges) (ebay)
B-C - 45mm Alloy coupler (with flanges) (ebay)
C-D - 45mm Intercooler (ebay)
D-E - 54-45mm Alloy reducer (with flanges) (ebay)
Clips
A, E = 2x Jubliee Clips (come with cooler)
B, C, D = 6x 52mm - 55mm T BOLT CLIPS (ebay)
Install Sensor into Intercooler
Installing the sensor directly into the cooler saves your original inlet sensor pipe if you want to reverse the mod.
1 - Bore out existing hole
2 - Drill and tap fasteners for VW sensor
3 - Seal with rubber or sealant
Install Bonnet Ducting and Brackets
Short-nose
Long-nose
Matching the bracket to the Intercooler
The holes don’t match so you’ll need to match them up - 6mm drill.
Bending the brackets
Install both brackets
Attach the anti-vibration mounts to the intercooler
Applying firm pressure with both hands bend the lower bracket down until the I/C fits easily.
Pipework
Trim the U-bends so that the straight part is as short as possible onto the intercooler - this gives more clearance to the bulkhead
Remove the original plastic inlet pipe and keep
Fit the reducers to the Turbo and Inlet - leave clamps loose
Assemble remaining pipework and trim as needed
You’re Pretty Much Done
Just tidy up and go get a remap
Better still get some ProjectPower2 injectors before the remap
Other Projects
EGR - Blank
Inlet clean
PP2 -
https://www.redlineforums.comthreads/51256/
5th Gear thread -
https://www.redlineforums.comthreads/83109/
Remap
