Map Sensor values
1 reading
13K views 21 replies 8 participants last post by  Corbym
#1 ·
I have just done a scan of my 2.5 TDI AJT engine with VCDS and found the following faults.
G71 fault short to earth.
G72 fault short to positive.
I carried out a further test as per these instructions:- http://www.vwt4forum.co.uk/showthread.php?t=84104
The values shown on my T4 with engine off were
1. 1275 mg/str
2. 979.2 mbar
3. 979.2 mbar
4. 0%
With the engine running at idle the values shown were:-
1. 455 mg/str
2. 979.2 mbar
3. 979.2 mbar
4. 0%
When I disconnected the MAP sensor the value of 3 fell to @ 400 mbar then went back up to 979.2 mbar as it should.
I then disconnected the MAF sensor plug and the value of 1 went up to around 1000 mg/str.
When I reconnected the MAF sensor plug the value dropped back to 455 mg/str
I then cleared the codes, switched everything off then I retested and the codes were still clear.
Would the fact that the value of 1. dropping from 1275 with engine off to 455 with engine at idle point to a fault somewhere else as it is showing that not enough air is being drawn into the engine.
Or am I missing something?.
I recently replaced the Air Filter so that should be Ok.
#5 ·
Update.
Just managed to run the test on my MAF using VCDS.
Didn't manage to get 100% load or over 3000 revs due to traffic ( never ending )
The readings for group 10 were:-
1. 860 mg/st
2. 999,6 mbar
3. 1897.2 mbar
4. 82% load
The readings for group 2 were:-
1. 2856/min
2. 100% load
3. 0
4. 90 degrees C
Two fault codes have reappeared following Auto Scan.
17564 G71 Manifold Pressure Sensor P1156 -35-00 Open short to ground.
17569 G72 Manifold Temp Sensor P1161-35-00 Open short to plus.
Is it possible to test these G71 and G72 valves?.
What detrimental affect could these faults have on the performance / fuel economy of my T4?.
#6 · (Edited)
From what I understand (not much!) with the engine off, those values look about right to me; no boost would leave the sensor reading atmospheric pressure approx. 1 bar at sea level. So a little less above sea level dependent on your absolute height.
At idle, you'll be seeing very little (if any) so again. Around atmospheric should be about right. A little lower though as the little exhaust gases that are expelled will spin the turbo a tad. At 3000 revs/m, with you kicking out a fair amount of exhaust gases from the head; I would expect to see more than 999mbar at 100% load and from this codes I would assume that the MAP (or something along that circuit) is toast.
That being said, I'm nowhere near 100% confident in my assumptions.
I'll give it a look when I'm 100% sober in the morning.
Also, what MAP/IAT sensor are you running? The all-in-one later one perchance?
#7 ·
With a non throttled / egr closed diesel engine at idle, divide the cc by the number of cylinders and MAF mg/st (milligrams per stroke) should be near, if MAF is good.
2500cc / 5cyl = 500 mg/st
I take it in group 10 blocks 2 and 3 are for actual and desired, that to me would say MAP is goosed...
#11 ·
My 2.5 TDI has had the EGR cleaned and blanked.
The MAP sensor is located as shown in the photo:-
Not sure where the Manifold temp sensor is located.:confused:
I have had a look at the wires around the MAP and followed them to the loom but cannot see any broken wires.
Is it worth checking inside the ECU to see if any wires have broken or worked loose?.
If so is there a How To Guide on removing and checking inside the ECU?.
Some of the small diameter pipes look a little rough but I haven't found any leaks yet unless they are perished.
Would it be worth changing those small diameter pipes and if so what diameter and lengths of pipe would I need?.
#13 ·
Thanks for the replies.
ÂŁ35 on the Bay of E for a new genuine 038 906 051 B sensor.
Does that sound like a reasonable price please?.
Is it possible to buy a ready made set up of pipes and securing / jointing clips for the AJT engine and if so does anyone have a link please?.
If I were to just buy lengths of suitably sized small bore piping then what diameters would I need and what overall length of each size please?. Can I also buy new clips to secure the piping to the joints?.
Has anyone done a " How To Guide " for replacing the small bore pipes or could you provide a link please?.
#18 ·
:) Does your van go into limp mode?
I had a problem where it would occaisionally go into limp mode, long story short it was the loom.
As the plug and wires lead to/from the MAP sensor (temp too, integrated twin sensor) and dissapear into the main loom adjacent to the expansion tank, peel back the outer corrugated protective sheething from the main loom and the feed to the MAP sensor, I had two wires breaking down, just where it bends through 120 degrees from the main loom to the tail, the sections were replaced and spliced and it's been all good since.
(I bought a new sensor from VW, not needed :( VAG com pointed to the sensor, what was I to know LOL: )
Chris
#21 ·
:) All of the sheathing on the spur, and about 40mm up and down from the join, the protective sheething seperates easily enough and it was obvious.
My problem was intermittent, fine for a while then iffy, I thought it was the sensor breaking down (VAG com indicated)
It was a short in the power feed and another cable, rubbing on the bend I think wore on the insulation.
Cheap to check to eliminate, it just read that you perhaps had not gone that far into the main loom.
Let us know how you get on.
Chris
