Hi everyone,
My roof-mounted solar panel has died. I've spent some time with a multimeter and narrowed it down to one of the "cells"/squares, but can't see any obvious failure which I can fix. So- I need to replace the panel.
I believe it's a 100W Biard panel, fitted three years ago. It's stuck with (I assume) sikaflex to the (Reimo LWB) roof. All of the wires/connections and controller are fine and can be re-used.
I'm confident on the electronics, but haven't ever done anything with Sikaflex. Or the removal of it. Options seem to be:
Option 2 is preferable, but might be beyond my DIY confidence. Uberbus is within an hour of Shaftesbury, Dorset, so I might see if they can help, unless there are others closer.
I'd appreciate thoughts on options 1/2 and level of skill required?
- Keep dead panel in place, and bond new matched panel directly on top (easy DIY), giving a rise of say 5mm.
- Remove panel somehow, remove sikaflex, bond new one in place
